Salta al contenuto principale
Il Dell Inspiron 3179 è un laptop convertibile 2-in-1 della serie Dell Inspiron 11 3000. È un laptop leggero, facilmente trasportabile e dal prezzo relativamente basso, disponibile in quattro opzioni di colore.
Hdd data interposed installation.
Hi, I bought an Inspiron 3180 and it has 32gb emmc storage. Upon upgrading the ram I noticed soldering points for an interposer labeled HDD1, must have used the same motherboard as models with hard drives. I was wondering if there is a part out there that I can solder an interposer connector to install a 2.5 in. SSD? There's enough space in the chassis for a hard drive. I could affix it with tape. Was wondering if this sort of project is possible and if so what part would I need, I'm having trouble finding one and Dell hasn't been much help. Helpful but not completely. Thanks for the read.
Update (08/10/2019)
Immagine
Immagine
I’m not sure how the posting of pictures works, I hope these pictures help in answering my question. It appears that an interposer connector could be put in but I cant find the part from Dell.
Questa è una buona domanda?
Punteggio 0
1 Commento
@dchar2189 post some good pictures with your question. that way we can see what you see. Yes, it is possible that this would work. Just a matter of trying to find out what exact number your motherboard is
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
@dchar2189 sure looks like all you need to do is to solder a connector to that area. Issues that could arise from that is that we do not know what connection goes where and hopefully everyone adhered to the standard.
Immagine
Check something like this connector, you may have to bend the piece on the ends up to fit your board. D:\DocManager\Check In\Vincent\ECR-10-004449\2023246-c SH1-A3 (1). from what we can see on your picture and checking the dimensions, it may just fit. Check this connector as well as this one which would be great since it is a slimline version. I see no reason why not to try it.
Punteggio 3
2 Commenti:
It looks to be exactly what I'm looking for having some trouble ordering it though, will keep you posted.
da Condividi
@dchar2189 please do. Would love to hear how it turns out. BTW welcome to iFixit.
da Condividi
Aggiungi la tua risposta
David Charette sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 23
Tutti i Tempi: 420
