Salta al contenuto principale
Il OnePlus 6T è uno smartphone Android prodotto da OnePlus. È stato annunciato il 29 ottobre 2018 e rilasciato il 6 novembre 2018.
Volume button got dented in
I sent my phone out for repair but they are saying the LCD assembly got damaged as well, is that possible for a small dent on the volume button to cause that damage?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
is the volume button near any support or construction of the phone? Maybe they meant that the button cannot seat properly but I am not too sure.
Sorry I do not understand what you are asking
Could you expand please
Punteggio 0
Volume been dented in may be beacause the push connector on the inside which is on a cable maybe damaged
Is there damage to the frame of the phone by the Volume button
Punteggio 0
1 Commento:
Hi Jerry! Okay, the volume button was dented in with the frame of the phone rendering the button unpressable. I am not sure about the construction of the phone or anything that has to do with the internals of the phone but all I know is that the frame and the volume button are fused together.
da
The volume button and the frame are not fused together
Punteggio 0
1 Commento:
Yes, I understand that but do you think I can remove the volume button from the phone and bend it back into place. Then after I do that, I can sand the frame of the phone just a bit so that the volume button can move back and forth.
da
If the main frame is bent . The best think to do is to get a new casing and transfter everythink over to it
If it working fine why not leave thinks has they are
Punteggio 0
1 Commento:
Yeah I might do that but the whole frame costs 140 dollars and this is just to repair the volume button. Is there any way I can just repair the volume button itself?
da
Full frame with all buttons
https://www.ebay.ie/itm/173463031607
Punteggio 0
Aggiungi la tua risposta
WARBUSCUS sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 20
Tutti i Tempi: 641
