Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Help with Glass only screen repair (Not lcd repair)
I have done many repairs before so I am not a total noob however I have just recently attempted to do a glass only screen repair on an iPhone 7, I got the glass of perfectly without problem but the glue that remains on the lcd seems impossible to get off without breaking the lcd even though im using 99.9% isopropyl alcohol. Any tips on how to overcome this? thanks in advanced.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Just use the adhesive removal tool it's a heated scraper that cut through the glue.
Changing just the glass without all the tools required to do so sure seems like a total noob thing to do lol
da
I have been trying to use that and i feel like I’m having too scrape way too hard to get any adhesive off
da
Is it a handheld one or a proper one??? Make sure its heated enough... it should all just come off fairly easily, there is a chinese debonder liquid available that dissolves the glue as well but u have to be careful with it as it gets between the backlight if u havent removed that...
da
Aggiungi un commento
1 Risposta
It could be that you are trying to take the polarizing layer off in which case you would have to fully remove it and buy a new polarizing layer. If not, try using acetone.
Punteggio 0
Aggiungi la tua risposta
Haris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 57
