Salta al contenuto principale
Informazioni di riparazione e soluzione problemi per il Dell Alienware 13 R3, un portatile da gaming prodotto da Dell.
Red light flashes but does boot.
This a work computer that was gutted and by an ex-employee. I am trying to put it back together however it won’t boot. If I hold the power button down for a few seconds red light pulsate but not thing happens. No fans ramping up or nothing. Please help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Are you using the original charger that comes with the laptop? Sometimes if the charger is not powerful enough / original it may refuse to charge the battery or power the laptop without battery.
Try these if you haven't already:
  • Powering it on without battery but charger plugged in.
  • Unplug any non major components for turning the laptop on such as USB daughter boards, optical drive, speaker cable.
  • If there is a coin battery present in the board try removing that for 5 minutes then put back in and try turning the laptop on. That resets the settings on the board's bios.
Punteggio 2
Aggiungi la tua risposta
Arnavick Tendilla sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 11
Tutti i Tempi: 4,923
