Salta al contenuto principale
Pubblicato a giugno 2017 come successore del Surface Pro 4. Noto anche come Microsoft Surface Pro da 12,3". Numero di modello: FJT-00001.
Bad battery, need to replace
Hello. I think I may need to replace the battery in my Surface pro 2017 if it gets any worse. Two years after I bought it I only get 3 hours of battery life. I see you have a surface pro 4 battery replacement video but I can’t find any specifically for Surface Pro 2017. Do the video and the tools for the Pro 4 also work for the Pro 2017? Any advice would be appreciated. Thanks!
Questa è una buona domanda?
Punteggio 5
2 Commenti
My customers surface only turns on when connect to charger
da
I bought a new battery ($50+) then cracked the screen ($200) and then broke the LCD touch screen connector ($10) which I am waiting for. So I’m in it for $260 to “change the battery.” Couldn’t find a place that would do it because the screen tends to crack. Not sure what I would do better next time but you may factor these costs in in making your decision to replace vs. buy new one. I had the same experience as you as far as battery life. I ended up buying a new Surface Pro 7 and am going to use my old one as a back up.
da
Aggiungi un commento
1 Risposta
Risposta più utile
@ilikegreen I would suggest to follow the guides and teardown from here After that proceed carefully the same way as the Surface Pro 4.
Punteggio 3
2 Commenti:
Thanks for the advice.
da
I do not see a battery replacement guide help!
da
Aggiungi la tua risposta
Richard Paulino sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 16
Tutti i Tempi: 1,959
