Salta al contenuto principale
Guide di riparazione, smontaggio e soluzione problemi per l'iPad Apple di quinta generazione con 4G LTE, disponibile con 32 o 128 GB di memoria. Rilasciato a marzo 2017. Identificabile dal numero di modello A1823. Dotato di display Retina da 9,7" e processore A9 a 64 bit.
What cable is this?
Can someone tell me what the correct name of this dual cable is is? (red arrow points to it)
I suspect it is some sort of antennae connection.
I was replacing a damaged glass front screen and they unfortunately broke - need to know if I can replace them.
Thank you in advance for any help.
Regards,
DLC
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
No unfortunately if it's the one on the digi then u need to replace the digitizer, if it's the one in ur fingers then that's for the home button u can replace that one with a new home button flex
Punteggio 1
Risposta più utile
Those are the digitizer cables that transmits the touch inputs of the user. If you broke those, you need a new screen: iPad 5 Screen Digitizer
Immagine Replace a screen compatible with iPad 5 A1822 A1823 and iPad Air (1st Gen) A1474 and A1475. Includes all of the small parts preinstalled in the assembly. Part #821-4894-A.
Prodotto
$44.99
Punteggio 1
2 Commenti:
Sorry u beat me by a minute lol
da
Thank you, fortunately I had already bought a screen replacement, and lo, said cables are pre-attached - just hadn't opened the box yet. Thanks much for providing the response.
da
Aggiungi la tua risposta
dlcatftwin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 366
