Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone 6s Battery Drain.. can be caused From LSD?
Hi everyone.. HI @refectio SIR
I have an iphone 6s with battery drain problem. Obviously i replace tristar battery dock connector check without everything connect, for verify if the problem is in MOTherboard.
During Microscope check i verify LSD Damage, phone work perfectly but have only Battery Draning problem. Abybody think it can cause from LSD damage? Thanks Guys
Questa è una buona domanda?
Punteggio 0
2 Commenti
That doesn't look like LSD damage to me. If you are uncertain, you can remove the standoff (it is soldered onto the board) and inspect it more closely.
da
@refectio Thanks a lot Sir..
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Is home button heating up (short circuit) by any chance while phone is on charger? I’ve had that happen a few times without noticing.
There are quite a few traces under that screw hole so better to check and see if they are shorting on ground plane.
Punteggio 2
1 Commento:
Thanks a lot @ben :))
da
Aggiungi la tua risposta
AGS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 230
