Salta al contenuto principale
La Canon EOS Rebel T3 è un proseguimento della linea di fotocamere DSLR entry-level di Canon, la serie Rebel. Conosciuta anche come EOS 1100D ed EOS Kiss X50, è dotata di un sensore della fotocamera da 12,2 MP e di un processore di immagine DIGIC 4.
How to fix error 30
An error 30 occured in my Canon D1100 EOS.. what shouild i do to fix this.. am even getting worse. help the one who knows the solution
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
@davie77 Err 30 seems to be vry common problem with this model
Description: A malfunction with the shutter has been detected.
Resolution: Turn the power off, then remove and re-install the battery. Then turn the power on again.
Other than that it sounds like a either a stuck or failed shutter. You could call Canon support for your place of residence and see if this is still covered under a “recall” that was happening a while back.
Punteggio 3
Error30 on Canon 1100SD> in fact the SD card reader has its oxidized contacts> I used contact spray for electronics with a little brush on the contacts of the SD card> I put the card back in the reader / removed and put it back several times / I leave to act overnight AND now no more errors30 ;-) —from a french guy
Punteggio 0
Aggiungi la tua risposta
Davie ogallo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 22
Tutti i Tempi: 2,681
