Salta al contenuto principale
Introdotto a fine 1986, il drive Apple 3.5 fu un'unità esterna per Floppy Drive Double Density 800k usata nella maggioranza delle piattaforme Apple dell'epoca.
Removing stuck yellow disk - Solved
Immagine
Trying to repair 800k external drive, but yellow disk stuck in mechanism and stopping me from removal of sliding trays. Need suggestions to move so I can continue to finish the tear down.
Questa è una buona domanda?
Punteggio 0
2 Commenti
The eject mechanism will not move the disk. See the picture of the drive with partial tear down. The yellow disk just won’t move.
da
Ok problem solved. After a few more shots of penetrating PB the slide mechanism finally broke loose after 30 years of inactivity.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
This model does not have a tray that ejects (slides out). It just sucks the disk in. To eject an inserted disk, press the eject button to the right of the slot. You can also try holding down the mouse button during start up of the Mac it’s attached to.
Smontaggio Drive esterno Floppy Apple 3.5
Punteggio 2
Aggiungi la tua risposta
GP Chanko sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 6
Ultimi 30 giorni: 25
Tutti i Tempi: 1,181
