Salta al contenuto principale
Rilasciato a settembre 2016. Identificato dal numero di modello SM-G610
Why is my back button not working
What causes some keys not to work sometimes? I discovered the return/back button on my phone wont respond to touch often times. This is frustrating because it makes using an app that requires a return function difficult.
Questa è una buona domanda?
Punteggio 6
3 Commenti
The same with my phone return button didn't work but when I tried to reset it works it features not the factory reset it work for several minutes only, then not working again, seems there's time elapse program to lock. I tried all options even the factory reset. The same happened working for several minutes only.
da
Can anybody suggest to solve this problem without going to any phone tech?
da
لقد سقط هاتفي مرات كثيرا علئ الارض
da
Aggiungi un commento
3 Risposte
Risposta più utile
Do you have a screen protector on the phone? If you do it could possibly just be a case of a bad cheap screen protector. If not it could be an actual issue with the buttons themselves. Or it could just be phone lag if they eventually do respond or if the phone freezes when you press them.
Hope this
Punteggio 1
I had this problam too, when i opened the phone there was a little water damage.
Are you sure it does not have any water damage…
Punteggio 0
My back button don't work at all
Punteggio 0
Aggiungi la tua risposta
Chinwe U-O sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 27
Tutti i Tempi: 6,370
