Salta al contenuto principale
La a7R II (modello n. ILCE‑7RM2) è la revisione del 2015 di Sony della loro fotocamera mirrorless full-frame a ottiche intercambiabili.
Immediately after turning camera on - camera error..
Immediately after turning it on, it clicks up and down the shutter on the display and in the viewfinder a camera error is displayed. Turn off the power then turn it on. Tell me what could be the problem. Can I diagnose the camera on my own? Tried to shake the camera a little does not help
Questa è una buona domanda?
Punteggio 0
2 Commenti:
any error codes? what is the exact message? do you have a lens on the camera?
da Condividi
No codes. message "Camera error.Turn power off than on." no matter with lens on camera or without.
This is almost a new camera. maybe 100 shots. Owner did't use it for a couple of years . Then he decided to sell it. everything was okay .he checked it. went to the meeting with the buyer on the bike. Turned on- there was this error.If a memory card is inserted, the red light flashes for a few moments.
recharging the battery from power bank works.
I'm not an expert, but it looks like the motherboard is working.
Inside there is a small ML621 Rechargeable 3V battery . May be dead.
da Condividi
Aggiungi un commento
2 Risposte
Shutter is stuck it seems. Follow this sony guide: https://us.community.sony.com/s/question...
Punteggio 0
1 Commento:
tried. didn't help.the sensor is not skewed like on youtube video,moves as if normal
da Condividi
Try to reset camera to factory default If possible. Remove battery and then press and hold power button for 10 second and then reinsert battery.
Different camera has different way to reset check manual.
Punteggio 0
1 Commento:
unfortunately does not help. Nothing happens
da Condividi
Aggiungi la tua risposta
Yuri Mironov sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 40
Tutti i Tempi: 2,065
