Salta al contenuto principale
La SanDisk Cruzer Glide è una chiavetta USB con connettore USB a scomparsa. È disponibile in diverse capacità di archiviazione con un corpo in plastica nera e rossa per tutti i modelli.
Is this Flash Drive fixable?
I accidentally droped the laptop that this was plugged in to… the cover for it split and when we went to plug it back in, it wasn’t showing up on the computer. I feel like this can be fixed easily since the connection to the motherboard is still intact… It’s just not showing up on the laptop.
Immagine
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
1 Commento
It probably cant be fixed unless you go to a professional so unless you have information you need on it then give up. Or if your lucky you can play around with it and it will work. Good luck
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
I agree that it probably can be fixed but easily…no. It’s hard to say from the pictures but when a USB drive is physically damaged, it usually means some traces on the circuit board are damaged. This can be fixed but it requires micro-soldering and that makes any DIY repair unlikely.
Here’s an example of the type of damage I am referring to.
Immagine
If you value the data on the drive, you could send your USB Drive to a micro-soldering repair specialist.
Punteggio 2
Aggiungi la tua risposta
Brett W sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 956
