Salta al contenuto principale
La Sony Cyber-shot DSC-W830 è una fotocamera da 20,1 megapixel progettata per acquisire immagini fisse e registrare video fino a 720 pixel.
How to fix error C:13:01? re-insert memory card?
I have sony DSC-W380, then suddenly after using cannot open file. the image was C:13:01, re insert memory card. how to fix it?
Questa è una buona domanda?
Punteggio 1
1 Commento:
I had the SAME PROBLEM! On the SAME CAMERA! I need to know this answer ASAP. I re inserted the memory card and that didn't work. I tried another card, that didn't work.
da
Aggiungi un commento
1 Risposta
I had this error about five years ago in a  Cybershot camera.  The error seemed to be caused by a bad contact  between the camera and the memory stick.
I gave the camera's slot a blast  of compressed air, cleaned the contacts of Camera & Memory Card and inserted &removed the  memory card several times in quick succession.
And this solved the issue.
Punteggio 0
3 Commenti:
I already did but its the same, no changes. =(
da
If there is no important data on it, try to format it using PC/laptop
da
cannot also detect on PC/Laptop. yes it has important data.
da
Aggiungi la tua risposta
Joefine sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 31
Tutti i Tempi: 4,409
