Salta al contenuto principale
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 Domande Visualizza tutte
Turned off no response at all while watching a movie
I was watching a movie and in the middle of it the tv just turned off and wouldnt respond even after I unplugged and replugged… its j52000 58 inch Samsung tv..
can you see anything on my picture which would tell u what could be the problem
Questa è una buona domanda?
Punteggio 0
3 Commenti
HI,
Does the standby light come on when you turn on the power to the TV?
da
Not at all ..
da
Hi,
Do you have a DMM (digital multimeter) and know how to use it?
No standby light means for a start that there is no standby power being provided by the power board.
What other power feeds, supplied by the power board, may be missing would have to be tested for using the meter.
If you don't know what you're doing you can cause more problems than what you have now including to yourself as there are lethal voltages present on the Power board when the TV is connected to the wall power outlet
If in doubt - don't, leave it to the experts
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check that fuse next to the AC in, Do you have a multimeter that will allow you to check continuity?
Punteggio 1
Aggiungi la tua risposta
Tin Runescape sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 47
