Salta al contenuto principale
Informazioni su riparazioni e manutenzione per il Huawei Mate 8, rilasciato nel novembre 2015. Ha sistema operativo Android in versione 6.0 e schermo da 6,0". Ha una fotocamera principale da 16 MP, una fotocamera frontale da 8 MP e una batteria Li-Po non rimovibile da 4000 mAh.
15 Domande Visualizza tutte
Does changing the battery also require us to change the screen?
I've been having battey charge drop problems. When I go to the Huawei service center they tell me that battery change will also require a screen change. (Without even checking my phone). They say that the battery comes with the screen. My screen is in perfect condition. Is it true that the battery change will also require a screen change?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
@slot1gamer @jayeff Thank you guys. It sounded silly to me as well when they said that the battery and screen both have to be replaced.
Punteggio 0
Risposta Più Utile
Hi @alieffendi ,
Looking at the Sostituzione batteria Huawei Mate 8 guide, it is not necessary to remove or replace the display.
If you decide to replace the battery yourself, read the comments at the bottom of the guide for a tip that may be of some help.
Punteggio 3
2 Commenti:
depending how you look at it, are you removing the screen or removing the back?? hmmmm
da
Hi @slot1gamer ,
Fair enough.
I've amended my answer.
Cheers
da
No they are being dumb..
The battery is stuck to the mid frame with some double sided tape, this is a job a day 1 tech can do.
Punteggio 1
Aggiungi la tua risposta
Ali Effendi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 92
