Salta al contenuto principale
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
483 Domande Visualizza tutte
Why does my washing machine pour water during the spin cycle?
Overview
My washing machine has an issue where it pours water during the spin cycle, while it is draining. Basically, it pours water from the top while draining it out from the bottom. It drains the water faster than it can pour it, so it does not actually fill with water, but it does re-wet the clothes, so the clothes are dripping wet when the cycle is complete.
It also agitates while filling with water. This is not much of a problem, but it started happening the same time that the other issue above started happening.
Specs
Model: Kenmore Elite 26964503
Desired Outcome
This is what the washing machine is supposed to do:
  1. Wash Cycle
    1. Fill with water.
    2. When full, begin agitating.
    3. After a while, drain water.
  2. Rinse Cycle
    1. Fill with water.
  3. Spin Cycle
    1. Spin while draining water.
    2. When empty, continue spinning and draining.
    3. After a while, stop.
Actual Outcome
This is what the washing machine actually does (the bold text marks the differences):
  1. Wash Cycle
    1. Fill with water while agitating.
    2. When full, continue agitating.
  2. Rinse Cycle
  3. Spin Cycle
    2. When empty, continue spinning and draining but also begin pouring water from top.
Summary
The main problem is 3-2: in the spin cycle, the machine begins to pour water after it has drained all of the water. It is not supposed to be pouring water at this point; it defeats the purpose of the spin cycle.
What could this be? What would cause it to pour water during the spin cycle?
Questa è una buona domanda?
Punteggio 7
14 Commenti
I have the same problem and the tub spins after the wash cycle and the clothes are dry, but the last spin cycle it must spray water cause it spins
da
Same problem. Anyone solved this? As a temp solution I have to close the water during spin cycle. Working till I get another washer
da
@Anthony Grech
What is the model number of the washer?
da
@jayeff. Part numbers I see at the back
I can’t match them anywhere.
Part No 3953357. WHT.
There are few more listed all start with 3953
Thanks Anthony
da
3953358 alm. 3953359 alm
da
Mostra altri 9 commenti
Aggiungi un commento
10 Risposte
Risposta Più Utile
If the spin light is flashing it means the load is unbalanced and it’s trying to fix itself. It will be “ the cycle that never ends.” Push pause, move stuff around or take something out and restart
Punteggio 3
1 Commento:
ou, easy fix! thanks, Ms. Taylor, you just solved my issue!
da
Same problem with my washer and I was directed to buy contact cleaner because the switch that controlled this function was thought to be sticking, which it probably was because after I bought the cleaner and learned what contact needed to be sprayed, it stopped sticking (on it’s own) and now after the initial water squirt at the beginning of the spin cycle, it shuts off and just spins out the clothes like it’s supposed to . At some point it will probably start sticking again and I will have to pop the top of the control panel off and spray the sticking part and hope that it works. If not the switch will have to be replace or the whole machine. I had this machine apart a year ago to fix the clutch because it wasn’t spinning at all. Not sure how long that repair will last but as my father used to say “that machine doesn’t owe me anything”.
Punteggio 1
4 Commenti:
Kenmore, High Efficiency, Series 500....High Efficiency uese more water ,more power and more of my time than my old Kenmore washer ...they should have given it another
Name....like money and time eater,sometimes 5 hours to do 1 load of clothes.
da
My washing machine just don't keep water as soon as the water comes in it also goes out without washing or doing anything at all
da
I have the same issue here
da
@Michael Olutade Your problem is do to the drain hose not being high enough from the floor. When drain hose is not high enough, gravity will siphon water out of the washer.
da
Every washer that I know will spray water over the clothes while it spins but only for a short time. It’s all part of rinsing detergent from clothes. No matter what, the clothes should only be damp after cycle is complete and not dripping wet. Spraying water while spinning is a good way to help remove soap from clothes. Most of the soap is removed on the second fill up. (rinse cycle) During the last 5 minutes of spin time, no water should be spraying on clothes. Never add water to the washer while it spins. Only the washer knows how much water is safe to use before motor over loads and burns out. Also, a Kenmore washer will fill and agitate at the same time on a permanent press cycle. Water line is usually half way up before both happens.
Punteggio 1
this is NOt a malfunction, many washers today either dont have a regular rinse and instead drain the. while spinning spray water to rinse the clothes , it saves water and is more effective then the old way of filling with water and agitation to rinse and some have both they will have a regular rinse and a spray rinse . now if the water pours the entire final spin then something is wrong a spray rinse doesn't last the entire spin cycle
Punteggio 1
Ok, so looking up your model number tells me that your washer is a direct drive Whirlpool on the inside. I would suspect the timer is getting to the end of its life. Part number WP8541110, over 100 bucks new from a supply house, maybe 50 bucks used on eBay. Could be the pressure switch, but I doubt it.
Punteggio 0
1 Commento:
I have an LG top loader model th2519ssak and having the same issue, spinning and spraying water occasionally and it doesn't end or taking too long to complete the spin. Any idea why this happens?
da
About a month ago I removed the top panel cover to access the the timer mechanism. I unplugged the power cord and put a paper towel under the timer. I sprayed contact cleaner in every opening I could find and spun the timer several times. After letting it dry for an hour I put everything back together and ran the washer through a cycle - same problem - argh. But ever since then (dozens of loads) it's been running fine. I think it was just a buildup of carbon dirt on some of the timer contacts that was causing my problem.
Punteggio 0
I have the same problem and think I have found a fix... check out the video below. I feel so empowered.
https://www.youtube.com/watch?v=Z1i0rOQX...
Punteggio 0
I’m not sure why but mine does same thing and my clothes are soaking wet when it’s done. Tried using the drain & spin cycle but still adds more water and they’re still sopping wet. It’s ridiculous!! I’ve stood here and watched water go into my clothes that were already soaked and too wet for the dryer and yet it’s still putting more water in there. Can’t it just wring out the darn clothes?!?!
Punteggio 0
1 Commento:
My GE machine does this too but it stops after about a minute into the spin cycle which I suspect is normal of this machine, In your case it could be a bad pressure switch or one that is not properly calibrated. May also need to clean out the air dome that the hose to the pressure switch is connected to which could be sending a false signal to the pressure switch. Worse case would be to turn off the water valve to the machine and let it spin until your clothing is dry.
da
My GE machine dumps water into the tub during the final spin too but it stops after about a minute or two into the cycle which I suspect is the normal operating condition of this machine to flush out any remaining rinse water from the bottom of the tub, In your case it could be a bad pressure switch or one that is not properly calibrated. Disconnect the hose and blow into it a few times (not too hard) and you should hear a clicking sound from the water level switch on the panel, Re-attach hose and run the spin cycle for at least a minute then reset the water level switch (that's the direction given on my GE machine service sheet). You may also need to clean out the air dome that the hose to the pressure switch is connected to which could be sending a false signal to the pressure switch. Worse case would be to turn off the water valve to the machine and let it spin until your clothing is dry.
Punteggio 0
All my washers did rinse during the rinse cycle would you just want it to fill up agitate and just drain it get the remainder of sope that may be e been hanging on after it drains. You want it to put water as it spins and drains it has a timer and then it should kick in towards the end spinning faster to keep them from beings wet wet if they are then you have a issue with timer on rinse cycle
Punteggio 0
Aggiungi la tua risposta
Dan Gorby sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 64
Ultimi 7 Giorni: 416
Ultimi 30 Giorni: 1,970
Tutti i Tempi: 79,816
