Salta al contenuto principale
The HP Envy 5660 e-all-in-one printer is meant to print, scan, and copy including features such as wireless printing and a color touchscreen. Model number: F8B04A
9 Domande Visualizza tutte
Paper Jam and gears grinding
The printer won’t print an error screen comes up stating paper jam. I followed all therir instructions and still don’t see a paper jam. As the cartridges move aross it sounds like the gears are grinding on the right side.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The reasons for this error can be different every time.
Step 1 : Check thoroughly for even a small piece of paper might be stucked in the printer.
Step 2 : Clean some of the gears inside the printer. After some years they need cleaning .
Step 3 : Some times there is an issue with a small elecromagnet inside the printer that is used to track the paper inside . For this step you might need to give the printer for repair. It still worth the money.
Punteggio 0
Aggiungi la tua risposta
Theresa Schafer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 557
