Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2265 Domande Visualizza tutte
iPhone 7 home button flex damaged.
Hi all
I have stupidly damaged the home button flex on a Iphone 7 and now will not work, after a close inspection of the flex I can see under magnification the tiniest of cut on the flex just before the flex bends close to the FPC connector, so if I replace the whole part will it function as a normal home/return button but without the fingerprint ID scanner?.
Colin.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Sent it off and had a micro-solder job done on it last week so that the touch ID would work again, all good now!
da
Aggiungi un commento
4 Risposte
there are some people on ebay who claim to beable to repair the homebutton flex, a very tricky job!
Punteggio 0
if you replace the home button it wont work as a home button and touch id wont work. there is however a special charge port you can buy and install that will allow the home button function to work just not touch id. https://www.unionrepair.com/new-charging...
or you can bring it to apple for a screen repair and they will fix the home button in the process.
Punteggio 0
There is a new homebutton that you can use that has the click function (home) but touch id dosent work, dosent need to change the charging port to use the newest replacing homebutton, just replace the homebutton.
If you want touch id to work a part of the flex cable need to be changed (microsolder)
Punteggio 0
Punteggio 0
Aggiungi la tua risposta
colin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 111
