Salta al contenuto principale
L'HP 15-r137wm TouchSmart monta un processore Intel Core i3 di quarta generazione con un display touchscreen ad alta definizione da 15,6" con retroilluminazione a LED. È dotato di 6 GB di RAM e di un disco rigido da 750 GB. L'HP 15-r137wm TouchSmart viene fornito completo di Windows 8. Il numero di modello dell'HP 15-r137wm TouchSmart è 15-r137wm, individuabile sul fondo del portatile, nell'angolo in basso a destra, sotto la batteria.
Keyboard Zif separated from MB
I have accidentally separated the keyboard Zif connector on my HP 15-n230sa laptop from the main board. Didn't realise the tab was on the opposite side of the connector and stupidly prised it off the board.
Please would you mind taking a look at the pictures and tell me whether this can be rectified? Is there anyway to reseat it back on the board?
Immagine
Immagine
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
1 Commento
I will find some who can re-solder this for me. Thank you very much for answering my question, much appreciated.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
You are very lucky! The solder pads didn’t get damaged so it should be possible to re-solder the connector back down.
Now the tricky part! To do this right you need a re-work system which uses hot air. Your best bet is to find someone local to you with the needed tools to remount it.
Punteggio 1
go to hit shows on utube, the fellow speaks mostly indian, but if you watch he cuts plastic to fit over the end of the ribbon and a small piece for tension on the underside and heats them and then inserts them and they hold solid.
Punteggio 0
Aggiungi la tua risposta
Andrew Hawker sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 20
Tutti i Tempi: 452
