Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
I put water on my laptop and it keeps moving.
Hello, a while ago I put some water/liquid substance on my laptop. Today, I saw the problems with my laptop. The cursor would go to the right, Chrome would zoom in, and other weird stuff would happen. I wiped the water off, but it still does this. This doesn't happen once I turn the laptop on, but in a matter of minutes.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
@robertb it looks like the appears to me that the water/liquid substance has shorted out the keyboard/trackpad. To replace it check on here
Sostituzione case superiore MacBook Pro 13" Unibody metà 2012
https://www.youtube.com/watch?v=EEs6Nl34...
Punteggio 4
If you spilled the liquid on the trackpad then you likely only need to replace it MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad following this guide: Sostituzione trackpad MacBook Pro Unibody 13" metà 2012
Immagine MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Prodotto
$59.99
Punteggio 2
Try disabling the touch screen mode and check if the cursor works fine. Then it seems to be some issue with the touchscreen sensor.
Punteggio -1
1 Commento:
No touch screen here!
da
Aggiungi la tua risposta
Robert Burton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 63
