Salta al contenuto principale
La Panasonic Lumix DMC-FH20 è una fotocamera digitale da 14,1 megapixel. È una fotocamera punta-e-scatta ed è disponibile nei colori nero, argento, rosso, viola e blu.
battery cannot be removed
after opening the compartment and releasing the lever inside the battery does not pop out as it used to and it can not be removed. how can it be removed?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione prescelta
thanks very much for your help!
Punteggio 1
Risposta più utile
@sbba1618 make sure that the locking mechanism is fully engaged. Sometimes it helps to push down a bit on the battery and see if that releases it. If that does not work, use a pair of hemostats or tweezers and try to pull it out with the release lever engaged.
Sostituzione batteria Panasonic Lumix DMC-FH20
Punteggio 3
3 Commenti:
thanks. i can not get something around the battery to grasp it as it does not move after release of the locking gear
da
@sbba1618 you may have to try to split the case and see if that releases the battery. It is possible that the safety latch has failed and stays engaged. This would of course involve a complete disassembly. Start with the posted guides
da
thanks a lot it finally came out I'm so happy:)
da
If your battery is older it may have swollen slightly, generally that's because you need to stop using that battery it's time to get another, AND the tweezers can work better if you warm the camera up, like put it near your body if your out so that there is less tug hassle. The swollenness of the batteries demonstrate that they are aged and need replacing.
Update (05/12/25)
The swollen batteries are a danger to health. Lithium ION batteries can explode, so try to remove and get rid of them safely.
Punteggio 1
1 Commento:
Adhesive tape may work to grab and pull (depending on the issue). It worked for me on a similar camera.
da
Aggiungi la tua risposta
s.a. sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 12
Ultimi 30 giorni: 46
Tutti i Tempi: 3,974
