Salta al contenuto principale
no volume control bar
Just picked up a used ipod touch but when listening to music i cannot turn up volume, control bar doesnt exist, ipod works fine when hooked up to a dock and there is sound coming out of the headphones.
Questa è una buona domanda?
Punteggio 5
1 Commento
when you say that the ipod works fine when hooked up to a dock, does that mean your volume bar shows up? What firmware ver is it? Does unplugging your ipod from the dock and unplugging the headphone make a difference? Have you tried a reset? First off, back up your ipod....
da Condividi
Aggiungi un commento
11 Risposte
Risposta più utile
Apparently there is a bug in the first generation iPod Touch (1G) with Apple’s OS 3.0 installed. Users are unable to change the volume using the usual double-tap of the home key.I guess what happened is that the assumption is made that the iPod has a volume switch and since the headphones are not plugged in , it must be connected to a dock. So make sure that you have proper headphones, since some of them can cause your volume bar to not reappear. So you could try to reconnect with new/different headphones or speakers, and see if the controls will show up. You could also try to restore your iPod with a different firmware, however, that will erase your data.There could also be issues with the audio jack. Let us know how it is going. Good Luck.
Punteggio 6
19 Commenti:
thank you all for your advise and opionions
I just got the ipod so it is "clean"(no info on it) i did an update in it and it is running 3.1.3, also did a restore, i have the original headphones(i think), have also tried others to no avail, not sure how to restore with "other" firmware other than what itunes supplies, i am getting sound out of jack and looks like headset goes in all the way and properly.
da Condividi
kevin, Check here for older and different iPod Touch firmware. It also tells you on top of that page how to do it. It might just be working for you.
da Condividi
ok i can figure all that out BUT not sure what file i should be adding the .ipsw to
da Condividi
The .ipsw is your firmware ;-) save it in a directory that you can remember and do a restore with itunes you can shift-click (PC) or option-click (Mac) the Restore or Update buttons in iTunes. A file dialog will open and let you choose the downloaded ipsw-file.
da Condividi
lol i realize that it is my firmware, every "file" i downloaded from the site has more than 1 file in the folder, none are labeled "firmware", so i am not sure which one i am suposed to be putting on.
da Condividi
Mostra 14 altri commenti
I found this on another site and it should fix the problem
"....I also have the 1st generation ipod and was also missing the volume slider. Here are the things I did to get it to work again....
1. Power off
2. Power on holding the power and sleep buttons until I saw the apple symbol.
3. Unplugged and plugged back in my headphones.
4. Slider appears only when headphones are plugged in....."
Worked like a charm. Literally - plug the earphone into the jack. Turn the iTouch off using the sleep wake button (i.e hold until you get a red slider) and THEN when you turn it back on, WHILE the apple symbol is still showing, unplug the earphones and put them back IMMEDIATELY (Apple still showing). I heard a noticeable difference in sound as soon as I did this - and when the iTouch finished rebooting I went to music and there was the slider and the volume was back to normal! :-)
Punteggio 3
3 Commenti:
Should the volume slider appear when plugged into my computer? It's not.
da Condividi
This actually worked for me on the first try! Thanks!!!
da Condividi
It worked for me on the first attempt too. Thank you!
da Condividi
Most likely, there is dust/debris in the dock connector. To clean the dock connector, use a toothbrush, and carefully "scrub" the connector. I've also seen this problem being solved by just restarting the iPod.
Punteggio 1
i have same problem with my ipod touch 1 , and i found it . mostly i think only problem on plug of the headphone :
to resolved it
1. unplugged headphone first, and play music like usually.
2. plugged back in headphones "slowly" and move to right, left, up and down until volume control bar exist again, or you cant fix the jack of the headphone to apple :)
Punteggio 1
2 Commenti:
I don't get a volume control bar when I plug in the headphones
da Condividi
Thank you VERY MUCH <3. This method help me a lot.
da Condividi
update to 3.1.3 and jailbreak!USE 3.1.2 to redsnow to jailbreak..
Punteggio 0
someone had has success solving this problem with the volume bar? i can't solve it, earphones ok, ios 3.1.3 E718 ipod touch 1g
help please!
Punteggio 0
hi! has you fixed the problem?
Punteggio 0
i tried hard to find the volume bar because on my old one it was a slide bar. lol
Punteggio 0
com.apple.iapd.plist
delete it...
Punteggio 0
Hi I'm using the iPod touch 1 generation the really old one and ok my music is playing when I put the head phone in but I can only hear it very very very lightly and my volume bar isn't there at all so there is no other way to turn it up bc it keeps on playing then goes off and it affected when I go on YouTube it plays then I hear nothin it just dissapears the volume all I see is rewind fast foward and play can someone help me please how do I Honestly fix this
Punteggio 0
There are no external speakers on the 1st generation iPod touch. You can only use it with headphones or a dock speaker.
Punteggio 0
1 Commento:
Will it work if it is plugged into my computer, that has it's own speakers?
da Condividi
Aggiungi la tua risposta
kevin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 33
Tutti i Tempi: 40,073
