Salta al contenuto principale
Rilasciato nel 2012, è un PC portatile resistente per l'utente informatico di tutti i giorni. Questo modello (NP540U3C-A01UB) è dotato di uno schermo da 13", un hard disk da 500 GB, 4 GB di RAM, un masterizzatore DVD ed è in grado di eseguire Windows 8.1.
Help, can't install an OS
So here’s what happened, I tried to install Ubuntu onto my laptop and when I restarted it, well it didn’t detect any OS anymore despite me leaving the USB inside. (It was originally a windows 10)
Now whatever I do, it doesn’t detect any USB input, let it be a USB keyboard, mouse or drive. The only thing I have access to is my BIOS.
It doesn’t seem like my laptop still has an OS and it refuses to do anything else.
Letting it boot normally gives me:
“All boot options are tried. Press F4 key to recover with factory image using Recovery…“
After pressing F4, well it doesn’t detect anything and goes on it’s merry way back to the afore mentioned quote.
Thanks is advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @kansysaea ,
In BIOS change the Fast BIOS mode setting to disabled
When Fast Bios mode is enabled it skips USB check during POST.
Go to BIOS > Advanced > Fast BIOS mode
When exiting BIOS (F10) save the changes (Y).
When the laptop restarts you should be able to boot from a USB device.
Punteggio 3
2 Commenti:
thank you very much @jayeff for your wonderful advice. It works
da
Thanks jayeff ! , works too in UEFI mode
da
Aggiungi la tua risposta
Andrew Kansy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 2,020
