Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Unable to activate - error.
Trying to set up this iPhone 6s and I keep on getting this message.
Unable to Activate
An update is required to activate your iPhone.
I have put it into restore mode twice now into iTunes on my Mac and attempted to Update & Restore. Still coming back with the same thing. Haven’t tried just restoring but it’s saying it needs an update. Also has the small exclamation mark in the top left hand corner with a “No Service” sign next to it, even though it has a SIM in it.
Any help would be much appreciated.
— Sam :)
Questa è una buona domanda?
Punteggio 36
13 Commenti
Iphone 6
Unable to activate
Solution
da
I have no clue how on earth is this website gained enough SEO To be this high up in this search there’s absolutely zero knowledge or advice on this page is absolutely useless
da
If you have a question, ask. If you have a better answer you're free to contribute, anytime. Criticism is always welcome, pointless whining is useless.
da
hi
i dont active my phone
after update whit itunse back again to unable to activate your phone page
da
i can't activate iphone 6s after update.unable to activate an update is recuired to active.please help me
da
Mostra altri 8 commenti
Aggiungi un commento
11 Risposte
Risposta Più Utile
I think your phone not have IMEI now.... Check on Activision screen symbol “I “ ….. When you not see the IMEI is baseband problém... Without IMEI not possible
Punteggio 12
5 Commenti:
@vojtech So, without the IMEI it's impossible to restore?
da
what do you mean that there is ni imei how is it possible
da
how imei not show in the iphone is it some things are missed or stolen
board
da
A fault in baseband circuitry is enough to have a phone being unable to provide the associated IMEI code. Nothing to do with a stolen board.
da
how solution???
da
Follow these steps:
  1. Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
  2. If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
  3. Restart your iPhone (Skip since you have tried this method).
  4. If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
  1. Make sure that you have the latest version of iTunes.
  2. Check that your computer has an Internet connection.
  3. Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
  4. Wait while iTunes detects and activates your iPhone:
  5. If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
  6. If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
If all of the methods not working, try to contact Apple Support.
Punteggio 4
iUnable to activate related to baseband issues.If the phone fails to detect IMEI while on activating the phones.There is common problem shows on.The way of repair that problem
.1- BBPMU reball
2- Wtr problem
3- BBCPU reball
That need to hardware skill that can`t be fixed with software.
Punteggio 2
Sim not valid iphone6s
Punteggio 2
Here's a bypass to get more usability out of your device (not a complete fix)
https://youtu.be/3NSWsWeINC8
Punteggio 1
My iPhone not activated no service
Punteggio 1
1 Commento:
My iPhone no service problem not activated
da
Why showing unable to activate
Punteggio 1
My iphone like this this for 1 week now i cant call nothing. and now i cant live.
Punteggio 0
my iphone 6s unable to activate
Punteggio 0
my problem is that my iPhone is saying unable to activate ,You iPhone could not activated because the activation server cannot be reached
Punteggio 0
You have to jailbreak it with ramdisk and create new apple id
Punteggio 0
Aggiungi la tua risposta
Sam Mileberg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 52
Tutti i Tempi: 34,218
