Salta al contenuto principale
Rilasciato nel gennaio 2016, identificabile dal numero di modello BDP-S3700
Why does the open/close button not work
I have disconnected both the audio and HDMI cable from my device.
After turning on the device, pressing the open/close button has not effect. The green power led is on.
I have tried resetting by holding on the open/close button, and the plugging in the power cord. This did not fix the problem.
Any suggestions or advice would be gratefully received.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@igreid wonder if it is in demo mode. While the player is turned on, press  ■ (stop) , RETURN, (pause), and then the SUBTITLE  button on the remote to disable it.
You can also try to open the case by inserting a paperclip in the hole of the drive
Immagine
Punteggio 2
1 Commento:
Thanks for the suggestion. This did not help.
This is the second unit I have had this issue with
Not sure what to do next.
da
Aggiungi la tua risposta
Ian Reid sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 28
Tutti i Tempi: 441
