Salta al contenuto principale
La Canon PowerShot A590 IS è una fotocamera digitale punta-e-scatta da 8 megapixel con zoom ottico 4x e schermo LCD da 2,5 pollici.
Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione prescelta
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
Punteggio 2
lens do not get back when on/off button is pressed.
Punteggio 2
1 Commento:
same answer as above :-)
da
make sure you are not holding the lens when you turn the camera on.
Punteggio 1
can you help for restart the camera
Punteggio 1
1 Commento:
Camera lens does not move when switch.
da
Aggiungi la tua risposta
Pinky Kasotia sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 6,609
