Salta al contenuto principale
Modello A1311 / Metà 2010 / Processore Core i3 da 3,06 e 3,2 GHz o Core i5 da 3,6 GHz
342 Domande Visualizza tutte
ribbon connection under black tape over it goes where?
On the back of the lcd screen, upper right under black tape is a ribbon connector with #593-1090-A on it. I’m putting screens on to other imac’s and the ribbon’s not on the other new one or the old broke screen either. ribbon has 4 contacts on the end. can anyone tell me where it goes and if i need to use it?
Questa è una buona domanda?
Punteggio 0
1 Commento
Are you sure you got the correct display? Sounds like you didn't.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@lynnwood53
that is your V(ertical)-sync cable. It connects to your LED driver board Installazione del display nell'iMac Intel EMC 2389 da 21,5" step 5
It may help if you post some pictures of your panel etc., that way we can see what you see and it may be easier to figure out what you are after. It sounds like you are saying your old LCD panel did not have this cable.
Aggiungere immagini ad una domanda
Immagine iMac Intel 21.5" EMC 2389 Display
Guida
Difficoltà:
Moderato
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Punteggio 2
Aggiungi la tua risposta
Allynn Wood sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 93
