Salta al contenuto principale
Rilasciato nel settembre 2013, il Gigabyte P34G è un PC portatile da gioco da 14" con processore Intel® Core™ i7-4700HQ di quarta generazione (2,4 GHz-3,4 GHz).
Battery replacement doesn't work
With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!
My charger specification is : output 19.5V ; 7.7A
My battery specification is : Battery Volt: 10.8/11.1V / Battery Capacity: 4300mAh/47.73Wh
My PC is : P34GV2
I buy it here:
http://www.laptop-battery.us/gncc30-giga...
This is the second battery replacement i do because the first was doing the same thing and it was returned
How its possible and what can i do?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hello,
now the situation has change…
I have two os in my laptop linux and windows. The first test i do it was to test with my principal os Linux and the result is my first message here.
So i tried to test it on windows and on it, the battery work good with a good charge and discharge ect, but when i boot in linux the laptop won’t boot or run without ac charger and when i unplugged it the, os poweroff suddendly…and the same happen with a live cd.
I don’t understand where is the problem, if is the battery a lot exotical discount fabrication and also that explain the poor compatibility? or there is parameter in bios or others things that i don’t know?…
da Condividi
Aggiungi un commento
3 Risposte
“With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!”
2 reasons why you may be experiencing this issue:
  1. both the batteries you purchased my have been faulty.
  2. there is an issue with the motherboard getting power from the battery.
Possible solutions:
  1. replace battery again, if that doesn’t work then
  2. repair the motherboard (although sourcing information and parts may be difficult) or
  3. replace the motherboard
Punteggio 0
1 Commento:
Hello,
da Condividi
your must buy a defective item,for your Gigabyte P34GV2 battery please look at our link:
http://www.laptopower.com/GNC-C30?search...
we have 1 year warranty
thanks
Punteggio 0
If it has one, disconnect the power button board and/or the charging port board, clean the contacts and then reconnect it.
Punteggio 0
Aggiungi la tua risposta
Ki Ko sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 36
Tutti i Tempi: 659
