Salta al contenuto principale
Numero di modello A75-S226. Processore: Intel Mobile Pentium 4 3,06 GHz. Memoria installata: 512 MB (DDR SDRAM). Disco rigido: 60 GB EIDE, 4200 giri/min.
does not connect wifi
where can i get a wifi card for this toshiba?
Questa è una buona domanda?
Punteggio 0
1 Commento
bonefont51, give us a bit more information. Why do you think you need a new wifi card? You checked all your settings? Did you check your BIOS, is your wifi recognized? What OS are you using? Anything happened to your computer? Did it stop working all of a sudden?
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
bonefont52, did you check to make sure that you wifi is turned on? Not knowing what OS you are using, I would check the BIOS and see if your wifi shows up and is recognized. Also check on here for more info. Try to reinstall the driver for your wifi, it is available here. If you do want a new card for whatever reason just check on Google there are plenty out there. Good Luck
Punteggio 2
ebay
Punteggio 0
Aggiungi la tua risposta
bonefont52 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 1,446
