Salta al contenuto principale
Guide di riparazione e supporto per un'ampia gamma di orologi.
Display Screen Electrical Connections
Attached is a picture of the display screen for a Brookstone clock. A ribbon cable was attached to the black pads shown in the picture apparently by either electrical conducting glue or something in the ribbon cable covering works as glue when heated? The second part of the question is I see not electrical leads from the pads into the screen. How does such a system work?
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Look at it vary carefully with the light at different angles and you should see very faint almost completely transparent conducting tracks. There’s a picture of a calculator display showing the tracks at https://wiki.restarters.net/Connectors#E...
Punteggio 2
Aggiungi la tua risposta
Carroll Stroh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 29
Tutti i Tempi: 440
