Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
197 Domande Visualizza tutte
Is it possible to have both a SATA III SSD + PCIe SSD?
Hello friends ,
I have a Mac Mini Late 2014 which I upgraded to a SATA III (6.0 Gb/s) SSD Samsung EVO.
I want to know if I can add a PCIe SSD in as well.
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
If your SATA SSD/HDD is like the SSD I linked below then yes. If your blade SSD is like the blade SSD I linked below then yes. Any other type of SSDHDD/Blade SSD then you will need an external enclosure and to use it as an external startup drive.
Crucial MX500 250 GB SSD
Sostituzione hard drive Mac Mini, versione fine 2014
[prodotto collegato mancante o disabilitato: IF123-123]
Sostituzione SSD Mac Mini fine 2014
Immagine Crucial MX500 250 GB SSD
Prodotto
$30.99
Immagine Mac mini Late 2014 SSD
Guida
Difficoltà:
Moderato
15 minutes
Immagine Mac mini Late 2014 Hard drive
Guida
Difficoltà:
Moderato
30 minutes - 2 hours
Punteggio 1
To clarify your Mac Mini has two ports one SATA were a standard 2.5" HDD or SSD will work and one Apple custom blade SSD.
It is not able to support a M.2 compliant SSD. So the answer is no you can't use a M.2 SSD in your Mac Mini.
But! You can add in the custom SSD cable and the custom SSD unit (the OWC Aura SSD in the link is also designed to work as well).
Here's a useful reference The Ultimate Guide to Apple’s Proprietary SSDs
Punteggio 1
2 Commenti:
Hi,
What is the needed SSD cable for OWC Aura SSD?
da
Here's the needed cable to add in the PCIe/AHCI SSD Flex cable for solid state drive (SSD)
This is the Guide you'll need to follow: Mac mini Late 2014 PCIe SSD Cable Replacement
da
Aggiungi la tua risposta
angeles.diego sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 430
