Salta al contenuto principale
Rilasciata a novembre 2013, identificabile tramite il numero di modello RVL-201 (USA).
Disassembling Wii Mini Case Component
I want to remove the white rubber piece inside the case component that stops the discs, so I can get another piece for replacement. How can I take it out? Is it friction-fit or glued on? I bought this brand new a month ago, so I don't want to break anything. Help will be very appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
it’s glued in sorry can’t take it out unless u use a hair dryer or a heat gun to melt the glue then replace it
Punteggio 1
2 Commenti:
Well, could I clean the front of it with something? I tried a couple of things, but nothing worked. It would have to either be cleaning it or taking it out and getting another one.
da Condividi
well you could try cleaning it with some windex
da Condividi
Aggiungi la tua risposta
Isaiah Austin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 32
Tutti i Tempi: 641
