Salta al contenuto principale
A1708 / EMC 2978 — Rilasciato a ottobre 2016, questo MacBook Pro entry-level mantiene i classici tasti funzione (al posto della Touch Bar OLED). La versione con tasti funzione monta un processore Intel Core i5 e due porte Thunderbolt 3.
Screen continuous flashing problem
Hi all,
I’ve facing screen flashing problem last few week.
I’ve tried SMC & NVRAM reset. But not work for me. Screen still flickering/flashing.
I’ve also format my Macbook and install fresh copy of macOS High Sierra. Yesterday, I’ve update macOS Mojave. Still facing flickering/flashing problem.
Note: When I’ve moving the cursor “screen doesn’t flickering/flashing”.
Also If I’ve play any video(only) in any player or play youtube video “screen doesn’t flickering/flashing”.
If I’ve Minimize the player or bowser “screen flickering/flashing”.
**I’ve tried plug in the power cord & remove the plug of power cord, still facing the problem.
Check the video and Please advice me.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
Soluzione prescelta
It seems to me from the video you got a stagelights effect too on the bottom. That might be usually caused by the screen itself, screen connector, or by resistors along the backlight circuitry. You can try reseating the connector (turn off and disconnect battery connector first) and clean the cable end with a couple drops >90% alcohol. Other than that there’s not much one can do apart from testing the logic board and/or trying out a different panel. Anything unusual happened to the Mac in the near past, bump or excessive humidity exposure ?
Punteggio 3
5 Commenti:
Reference the answer to this question Black shadows from the bottom of the screen
da Condividi
Here's a second question on the same subject Screen issues, Back light dims & goes out
da Condividi
@danj I had missed that one..it seems like a flood as with the old GPU issue on A1286, and just two years after release of brand new machines. Probably it's just the beginning. It should be like bread and butter for a lawyer with some good will. I hope it will serve well Apple's soldering and glueing craze.
da Condividi
Sadly it's a design issue with the newer interconnection cables between the system and lid (2016 and through 2018 models). I've now have seen 14 systems! All with either the stage lighting effect (backlight ribbon) of display wink out when the screen is tilted more than 45 degree's or (datas cable from T-CON board).
da Condividi
@danj I haven't been crossing any so far, but that's probably due to the fact that in Europe we have two years warranty by law and they're expiring right now. I'll brace for impact, it seems it's just a matter of time.
da Condividi
New Program
13-inch MacBook Pro Display Backlight Service Program
https://www.apple.com/support/13-inch-ma...
Punteggio 2
Aggiungi la tua risposta
Imam Hossain sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 31
Tutti i Tempi: 4,416
