Salta al contenuto principale
Disponibile per la prima volta nell'agosto 2014, identificabile tramite il numero di modello RCT6103W46.
google play / gmail
In May 2018 gmail no longer worked. Message says device does not support google play. What is the problem?????
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
This is a known error that has been going around older Android devices.
Pull down the notification bar on your Android device and hit the gear-shaped settings icon, or find “settings” in the application tray. From here navigate to Apps, or App Manager. Then scroll down and find Google Play Store. Select this, and tap Clear Cache or Data as shown below.
Report back if this fixes your problem or not.
Punteggio 0
1 Commento:
Clear cache or data was not an option. Google Play Services shows notifications - Blocked - cannot undo. Have tried to register device with google but not successful.
da
Aggiungi la tua risposta
Bobbie Monnett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 240
