Left side of screen clicks after screen repair.
After i repair my 6s screen, it continues to click terribly on the left side, ive opened it multiple times and still clicks, do i need the adhesive to make it stop?
Questa è una buona domanda?
I bet the new screen is bad (likely) or was damaged during installation (possible).
To verify this, put back the old screen if you still have it (and if it does show an image and has touch).
So to fix this, get a new screen from a reputable vendor that test their screens prior to shipping or at least carry good quality product and a warranty to match. I'd say iFixit.com is a great choice for this (we are not affiliated).
Before installing the new screen, clean the frame of the phone with acetone or some non-watery solvent and make sure you remove every bit of dirt, adhesive, double-tape, whatever was present from before. It should be so clean you'd eat off it. Apply a new adhesive seal, but don't remove the protection foil until you've tested the new screen, making sure of the following:
This guide shows you how to do the repair in details and links the needed parts and tools as well.
well I bought the new screen from ifixit so idk what else to do unless maybe its defective I guess but I don't got money to just be blowing on more screens, but I'll try the old one again maybe
@austin245 if the screen is not physically damaged from the 1st repair attempt, they would I think warranty it for you. Try to contact them.
2 potential issues here.
1 - There is pressure from the phone housing pushing the screen up. In which case remove the screen and inspect the lip that site on the outmost edge of where your screen pops into place. When Iphones are dropped it is not uncommon these take a dink and lean in. Because of this the new screen will not sit flush. Take a small hammer or vice and try to knock it back out. The screen will sit flush after there are no obstructions.
2 - There is an issue with the new screen. However unlikely this is. (option 1 works for me when I repair phones at work).
Nope, thanks though. Ended up sticking some getto adhesive on one side to stop the clicking until i buy a adhesive seal for the whole screen, seems to be because of lack of adhesive :P
bought adhesive and now clicks even worse
well I bought the new screen from ifixit so idk what else to do unless maybe its defective I guess but I don't money to just be blowing on more screens, but I'll try the old one again maybe
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 877
1 Commento
Added Adhesive and now the screen clicks even worse, im ready to just bring it in to a third party repair shop, i dont know what the &&^& to do anymore, PLUS the frame is not bent, so do not comment that.
da Austin Merrill
