Salta al contenuto principale
Lo smartphone Android Tecno Y3s è stato rilasciato da Tecno nell'aprile 2015.
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Questa è una buona domanda?
Punteggio 20
2 Commenti
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
da Condividi
Sir, my mobile battery is very weak, what should I do to get it fixed?
da Condividi
Aggiungi un commento
7 Risposte
Risposta più utile
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
Punteggio 3
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
Punteggio 3
To take a look on battery terminal if a well connected second to check life of battery
Punteggio 0
1 Commento:
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
da Condividi
Phone is not power on and showing logo
Punteggio 0
1 Commento:
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
da Condividi
My phone charging socket is not working
Punteggio 0
No problem my phone is ok
Punteggio 0
Charging my phone slow way
Punteggio 0
Aggiungi la tua risposta
Eric Matibila sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 16
Ultimi 30 giorni: 40
Tutti i Tempi: 3,654
