Salta al contenuto principale
Guide e supporto per varie marche e tipologie di televisioni (TV).
9059 Domande Visualizza tutte
Why is my TV overheating?
I have this TV for a couple of years now. It’s Quadro lcd-22CH21 tv. Yesterday the sound has changed. Video is perfectly fine but the sound is deformed and everything sounds like it’s from another galaxy. I have also noticed that he started to overheat. So I assume it caused the sound problem. Do you have any advice on how could I fix it or should I leave it to expert.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@scr00ge
for the overheating, that would depend on if your TV has a fan. You do want to go ahead and remove the back of your set. Then take agood look at all of the boards. Check for obviously damaged parts like domed or leaky capacitors. Take some pictures of the complete layout of the boards as well as all of the boards. Post those with your question. That way we can see what you see. Use this guide Aggiungere immagini ad una domanda for that. The main board is usually the board where you find the audio IC circuit. I would suggest you get a test speaker and hook it up to where your usual speaker is. See if that sounds different or same. If it has improved you know it is the speaker.
Of course, you checked all of your audio settings etc. before.
Punteggio 2
Aggiungi la tua risposta
Scrooge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 934
