Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
numerous keys stopped working
My Macbook keyboard has suddenly started having problems. the “enter” key, the ‘p’, and the numbers don’t respond at all. the ‘=’ key works but also adjusts the keyboard backlight for some reason. mouse keys are not enabled. any ideas of what could cause this short of replacing keyboard. i had been in a humid area for several days and it worked fine there but wasn’t working when i got home
Update (08/11/2018)
there are possibly other keys i haven't realized yet are not functioning or functioning improperly but those are what i've noticed
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
First run a “Paid For” anti-virus like Symantec Endpoint protection.
This failing you will need to replace the keyboard or the uppercase:
Sostituzione case superiore MacBook Pro 13" Unibody metà 2012
https://www.youtube.com/watch?v=UYW1xgUe...
Punteggio 1
Kindly go through the following knowledge base article:
macOS Sierra: If keys on your keyboard don’t work
Punteggio 0
1 Commento:
went through no luck. tried livecd of linux and keys still not working so i'm guessing i'll need to replace the keyboard. is there anything else i should consider first
da
Aggiungi la tua risposta
John Paul Logan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
