Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone 6S rear camera and flash issue (microsoldering)
Hello, i have iPhone 6S with minimal water damage. Rear camera and flashlight wont work. Tried changing camera.
After inspection i saw water damage near camera controller and FL3202 was completely burnned.
Changed U3200, C3210, FL3202, U4100
Camera and flash still doesnt work. What should i do now? have anyone faced this problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Check to make sure you have continuity between the PP_VCC_MAIN that goes to FL3202 and the PP_VCC_MAIN that powers the rest of the board. I’ve seen cases where the inner trace that connects the CPU area with PP_VCC_MAIN and the camera area gets vaporized internally.
Punteggio 2
Aggiungi la tua risposta
Madness sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 204
