Salta al contenuto principale
Dotato di lettore CD, ricevitore con sintonizzatore AM/FM, amplificatore MOSFET, frontalino estraibile con display LCD a una riga da 14 cifre e telecomando.
Why does Bluetooth keep pausing with pandora
Be playing fine then pause
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Pandora and Bluetooth can sometimes be finicky when used together. Pandora updates their service often, and that occasionally wreaks havoc on the Bluetooth connection, especially for car stereos. Here are a few things to try:
  1. Make sure you’ve got the latest version of Pandora software - check for app updates.
  2. Make sure you’ve got the latest version of OS on the device you’re running Pandora on.
  3. See if there’s a firmware update for your JVC car stereo - there probably isn’t but you can check on JVC’s website.
  4. Use the USB input on your JVC car stereo instead of Bluetooth - the USB connection is likely to be much more stable and trouble-free. Most JVC car stereos will let you keep the Bluetooth connection live for making calls even when you’re using the USB connection for streaming music.
Punteggio 0
Aggiungi la tua risposta
aaronnewman33 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 11
Tutti i Tempi: 1,315
