Salta al contenuto principale
Forward/reverse lever are backwards
Hi gang, I have a 2001 Club Car DS 4 stroke gas engine. Problem is small but it irks me that I cant seem to find the solution. When the cart is in the forward position it goes backwards and vice versa..,when its in the reverse position it goes forward. A little help please...chances are this is a simple fix but I guess I’m having a brain fart and cant figure it out.
Questa è una buona domanda?
Punteggio 1
1 Commento
That’s great looking into it now, I don’t see those studs but will explore a bit more.
Thanks a lot for your response, will keep you posted.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Look at the motor. On one end of the motor (the side closest to the gearbox) the studs will be labeled S1 and S2 (for a Series cart) or F1 and F2 (for a sepex cart). Take those two cables off and swap them and your problem should be rectified
Punteggio 2
6 Commenti:
Simple, brilliant answer.
da
I’m not sure what a sepex cart is...you do realize that I’m talking about a gas engine right?
da
No luck finding the two studs to swap over the cables, just dont see it. Sorry....thanks for trying though, appreciate it.
da
Mostra 1 altri commenti
The problem is someone has changed the motor. Earlier cc engines ran counter clock wise and the newer ones run clockwise hence your shifter works backwards
Punteggio 1
2 Commenti:
So does this reverse the gearing as well? Reverse gears should be lower than forward gears correct?
da
This seems to be the correct answer as my cart is the same way.
da
Aggiungi la tua risposta
Den Gauthier sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 49
Tutti i Tempi: 2,471
