Salta al contenuto principale
Repair guides and support for your Samsung TV.
2614 Domande Visualizza tutte
Why cant I get reception with my HD out door antenna
TV receives perfectly with cable connection, but not with the out door antenna. Should I replace the receiver?
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi @thisisajoke
What television model is it and more info on your outdoor antenna, e.g. yagi... etc?
intending to receiving what kind of signal ? DVB-T2 ? or analogue?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @thisisajoke ,
What is the full model number of the TV?
Check the settings in the TV. depending on the model etc, some have a setting to select either antenna or cable as the input type.
Punteggio 2
Press the input button on your TV. Look for TV. Next fine antenna or air. Scan for channels. You may have to try this a few times....you may have to adjust your rabbit ears. Try this. Thanks for asking, Matt of Martins TV Repair.
Punteggio 0
Aggiungi la tua risposta
Joe Boyd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 27
