Why cant I get reception with my HD out door antenna
TV receives perfectly with cable connection, but not with the out door antenna. Should I replace the receiver?
Questa è una buona domanda?
Hi @thisisajoke ,
What is the full model number of the TV?
Check the settings in the TV. depending on the model etc, some have a setting to select either antenna or cable as the input type.
Press the input button on your TV. Look for TV. Next fine antenna or air. Scan for channels. You may have to try this a few times....you may have to adjust your rabbit ears. Try this. Thanks for asking, Matt of Martins TV Repair.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 27
1 Commento
Hi @thisisajoke
What television model is it and more info on your outdoor antenna, e.g. yagi... etc?
intending to receiving what kind of signal ? DVB-T2 ? or analogue?
da Augustine
