Salta al contenuto principale
Lo Shark Rocket HV301 è il secondo modello di aspirapolvere della serie 300. È un aspirapolvere due in uno dotato di diversi accessori, che lo rendono capace di pulire su superfici differenti. Il suo design elegante e leggero lo rende facile da manovrare in qualsiasi ambiente domestico.
No suction - not a filter or clogged hose
My Shark is a Rocket True Pet purchased from Walmart in 2015. Great vacuum until today. I vacuumed our hardwood floor of pet hair (maybe 15-20 minutes) and it did well. Went to vacuum a small carpet with dog hair and nothing. Running but not picking up. I've detached the main unit from everything and removed all filters. It turns on and sounds fine but no suction coming from tip. I see nothing else I can clean.
Questa è una buona domanda?
Punteggio 3
1 Commento
MINE HAS A CRACKED HOSE IN THE CARPET FOOT ATTACHMENT AND i CANNOT FIND A NEW FOOT
da
Aggiungi un commento
9 Risposte
Risposta più utile
Most people miss this one:
Cause 1
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Punteggio 5
5 Commenti:
Thanks but it's not a filter. With everything detached and removed the main unit turns on and sounds like it is working but has no suction.
da
Same thing here. I ran a cable through and no clogs, i changed all filters ,i checked brush roll. It lost suction power. It picks up a little bit and hardly anything. It will be 2 years old in 2 weeks. I ordered a dyson 3 animal extra. Im tired of this crap. Every shark plug in stick type vacuum only last me 2 years or less. I change filter every 2 to 3 months and i clean vacuum head roll every time if needed. Im not buying shark anymore
da
How long do you expect it to last? How much, total, did you pay for it and did you purchase the warranty? And could we possibly compare to, say a Kirby, and their practices?
da
Hello..I'm an old lady who has no handyman lol but I have learned how to fix a couple problems myself w shark rocket
Powerhead stopped working..troubleshoot the prob by placing motor w/o wand to PowerBar. If PowerBar works ots a connection in the wand
Open the prong areas to clean of debris or see loose wire in wand
Then no suction.replavwd w new filters still none.
Open the canister where you dump debris out and look inside the canister. There is a dome of.sorts with a screen on it
(I tried to take it out but I think it's molded in)
Take a toothbrush and brush all sides of the screen on the cone
Fixed!
da
Thank you. A round bouncy ball fits through every part except into the canister.
da
If your Shark vacuum is no longer picking up dust and debris, see the Shark ION Robot R75 Is Not Collecting Debris problem page for possible causes and solutions.
Punteggio 2
1 Commento:
Same issue.Brush ins.lght is off/no suction in up position.Removed panel/hair etc., and still same. Have suction detached.Noticed/1 of locks not locking.I kept trying which was not too smart because in the almost 3 year's of having this vacuum and the countless moment's fixing my accidental vacuum slurps, I've never had an issue with locks UNTIL...
I assumed and kept trying to turn the same way as the other 2 when the not very visible opposite lock position arrow caught my eye.
I could be mistaken BUT, I think this is why the light won't come on for the brush and why there's no suction upright when attached to brush. ?
Funny thing is that I thought I could just go to the website and get a replacement lock for the one of 3 that I stripped and nowhere are they located. Found this while searching and thought I'd share while saying hello....didn't want to just do a pixel cyber search drive by. 😉
If I'm correct, please let me know so I don't commit myself to the nursing home just yet.
Toodles
da
Hi
I’m no Shark expert but I know my Dysons like the back of my hand and I find when you can’t find the problem it tends to be a blockage from with in the cyclone (the bit that’s usually above where the dust collects)
You can do 1 of 2 things here
The best option is to completely disassemble the cyclone and hand clean all the parts with hot soapy water
The second option is Easier but doesn’t always work: if you can get a deep bucket and fill it up high and submerge the cyclone in the water and shake it up and down so all the water get is in a clean it ,leave it I. A warm room for a week to dry out
Hopefully this helps
If it doesn’t let me know and we can try something else
Punteggio 2
Busted motor, either get a new motor or get a brand new vac.
Punteggio 2
3 Commenti:
I tried to dissassemble the unit but Shark makes it more difficult by using different type of screws that normally you would have to find and buy that specific tool to remove those screws, plus the humming sound of my vac tells me that it might be time to replace it or maybe just replace the motor to save $$$, not gonna go to a professional cuz they might charge me more in the process. Hope this helps.
da
Amen to that! I'm on my second Shark Rocket Pro within 3 years, and I think the second one has a motor that stopped working. No suction at all and not due to plugged hoses or head. The motor looks spic'n span clean so I don't think it's due to clogged filter situation. My husband has taken it apart and he's perplexed as well. Looks like I'm heading to the store tomorrow to purchase a new vacuum, AGAIN!
da
@smgg
Before you buy new, call Shark. They will work with you. You may have to do a video chat with them. I’ve had the best luck calling Shark!!
da
Turn over the floor nozzle. Unlock 3 plastic holders with a coin. This will open the bottom panel. Check for any debris blocking the the air flow inside.
Punteggio 1
1 Commento:
I've now owed three shark hoover. Never again. The motors cleaned out all the filters made sure no blockage and like the two hoovers I've had before barely last two years. Expensive Rubbish.
da
I appreciated all of the helpful advice on my "no suction" issue. Unfortunately, my husband disassembled my Shark Rocket Pro without paying attention to the sequence and couldn't get it back together again. I had to pitch it into the garbage.
Punteggio 1
I absolutely love this page, I thoroughly enjoyed reading this information. This is my first Rocket Shark Cordless and my daughter started me on these sweepers. She is a professional cleaner and she swears by them to which I was extremely doubtful. Using this sweeper has been a game changer and when it stopped picking up , I simply couldn't do without it . I looked up what I could do to get it back going again and found this site. I had no idea the Rocket was so popular and that Rocket would get in with you for a video chat as well as the fact that they come with attachments. Outstanding and this site is a enjoyable wealth of information. Ty so much everyone and wish me luck on repairing my Rocket Shark.
Punteggio 1
You have a rip or hole in the lower hose.
Punteggio 0
there is a rather loud blowing/sucking sound and it picks up little to nothing
Punteggio 0
1 Commento:
I'm not sure what you want here. I described the problem
da
Aggiungi la tua risposta
varider424 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 21
Ultimi 7 giorni: 101
Ultimi 30 giorni: 413
Tutti i Tempi: 18,615
