Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per l'iPad Apple di seconda generazione con rete cellulare 3G CDMA (Verizon), disponibile con 16, 32 o 64 GB di spazio di archiviazione. È dotato di un processore dual-core A5. Rilasciato a marzo 2011. Identificato dal numero di modello A1397. Le riparazioni richiedono l'uso di calore e una leva eseguita con cura.
New screen not working
My ipad 2 suddenly stopped coming on. That is to say that the screen wouldn't power on or respond to the home button being pressed. When plugged into the computer, the device is recognised and if I didn't have a screen lock I'd be able to transfer data.
It was my thinking that the screen was broken and so I purchased a replacement screen for £20. It has a very sturdy and easy to fit cable, so I don't think I made any mistaked here, but the screen still does not come on.
Could this be a problem with the chipset, or perhaps by sheer bad luck did I buy a faulty replacement screen?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It could be the screen you buy, but a long time ago I had that problem with the same device, and it was the chipset, try to clean the main board with some isopropyl alcohol, but i don´t think that´s going to help you
Punteggio 0
Aggiungi la tua risposta
Alex McElroy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 263
