Salta al contenuto principale
Il Dell Inspiron 14R-5437 è un portatile sostitutivo del computer fisso in grado di durare a lungo. Con una batteria sostitutiva a 6 celle rimovibile e un processore Intel Core i3 di quarta generazione a basso consumo, l'Inspiron 14R-5437 ha la potenza necessaria per funzionare per quasi dieci ore.
ripped one of two LCD cables while disassembling.
I was taking apart my laptop to get to the motherboard to replace it (if you can, can you also send a link to a decently cheap motherboard for this laptop that has at least an i5 CPU?) and while trying to remove what the tutorial said was the LCD cable, i broke the smaller of the two connectors. here is the link to the tutorial that i used: https://www.parts-people.com/blog/2016/0... The LCD cable is step 15. I was wondering if the smaller cable was necessary for the booting of the computer, or if I have to find a way to get the cable to work again.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Leveler02 Gaming,
In the picture you described there is only one cable which they are uninstalling , and this is the LVDS cable which sends data to the display. This would be necessary to use the built in display in the laptop.
I hope this helps,
Charlie B
Punteggio 1
2 Commenti:
the other connector is hidden by his hand
da
was anything connected to that connector?
da
Aggiungi la tua risposta
Leveler02 Gaming sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 3
Tutti i Tempi: 407
