Salta al contenuto principale
La Toyota Prius è un'auto ibrida elettrica progettata da Toyota. La terza generazione, venduta dal 2009 al 2015, ha introdotto un nuovo design della carrozzeria con un coefficiente di resistenza aerodinamica inferiore.
Thermostate replacement 2014 Prius
I replaced my coolant at the dealership for my 2014 Toyota Prius at 50,000 miles . I asked the forum when you replace the thermostat . The answer was when the coolant was replaced , The dealer said they had never replaced a thermostat in a Prius . Their parts department said they had not ordered one either . Thermostats can't last forever . Is the dealer telling me the truth ? Advise ?
Questa è una buona domanda?
Punteggio 0
1 Commento
Thank you for your insightful answer ! Having the history of replacement of the thermostat helps me understand why its not replaced as often in other vehicles I have owned .
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
In the case of a Prius I wouldn't change the thermostat unless the car was overheating. Preventative maintenance is a good thing but in this case I would pass . The thermostat is hard to get to and requires a few hours of labor to replace. As for your statement "Thermostats can't last forever" no not forever but I know of a few vehicles with over 300000 mile that have never had theres changed . The dealer is probably being honest here . Most dealership look for ways to ding you . I would be thankful they didn't say they changed it when they hadn't and then charged you for it . Hope this helps
Punteggio 2
Aggiungi la tua risposta
fasteddie sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 13
Tutti i Tempi: 2,032
