Salta al contenuto principale
Rilasciato nel febbraio 2015, il Samsung Galaxy A7 utilizza il sistema operativo Android, è dotato di uno schermo Super AMOLED e di un processore octa-core.
Charging issue in mobile
while charging an error is raised - battery temperature too low. and phone is not getting charged. how can the problem be fixed?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
That message is usually shown from liquid damage on the charging port or components near the charging port.
To fix this problem it requires disassembling the phone, removing corrosion from the charging port, components near it and/or replacing the charging port.
Unfortunately on this model you will need to remove the screen first (with the risk of cracking the screen) to get access to the internals of the phone.
I would recommend to take it to a phone repair shop for diagnosing the problem.
If the phone still has warranty, it's better you take it to Samsung to get it fixed under warranty.
Punteggio 2
Aggiungi la tua risposta
sachin shinde sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 23
Tutti i Tempi: 847
