Salta al contenuto principale
Guide di riparazione e supporto per la prima generazione della fotocamera compatta di fascia alta Sony RX100 con sensore da 20,2 MP. La Sony Cyber-shot DSC-RX100 è stata rilasciata nel giugno 2012.
No power fuse location
My RX100V will not turn on. A shop suggested it could be a fuse. Where is said fuse and where might I find a new one?
Thank you.
Questa è una buona domanda?
Punteggio 3
5 Commenti
Did you get this fixed? I believe I have the same problem. Please let me know what you found.
da
I have the same on my Mk V. I dropped it about 3 ft on the grass. Totally dead. Hard to find anyone that will work on it. Tried a couple shops here in Houston. One told me to send it to some place in Vermont. I called them, they want over $400.00 to fix it. Not sure if it is worth it. I went back to using my Panasonic /Lumix. I have dropped that one onto a drive way off the roof, it has a dent butworks like a charm. I put the battery back in it, taped the battery access door shut, no problem. Would love to get my Sony fixed. Let me know if you have your repaired. I appreciate it. Thank you kindly.
da
Gary Griffith
Send me a message directly. I may have an option for you.
Dan
da
@abrsvc Thank you. Any help is greatly appreciated.
da
Gary, please post back here if you find a solution. My Mk. V is still here not working.
da
Aggiungi un commento
1 Risposta
Risposta più utile
If I recall correctly, all of the "fuses" in this camera are surface mounted fuses. These are about the size of a letter on a quarter. This is not a home owner repair. Some specialized equipment and experience is required for this repair. It will not be popping out a glass fuse and inserting another.
Sorry to bring bad news. The good news though, is that if the fuse is the problem, it is a relatively simple fix once you get to the area. BTW: the fuse should cost no more than $1.00
Dan
Punteggio 2
Aggiungi la tua risposta
Mike Hamende sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 24
Tutti i Tempi: 1,860
