Salta al contenuto principale
Il laptop con touch screen Asus VivoBook Q200E-BSI3T08 è stato prodotto da Asus nel 2012.
Spilled tiny bit of coffee
I spilled a tiny bit of coffee (probably less than half an ounce) on my laptop. It’s functioning perfectly fine with no problems whatsoever. I immediately dried it off and turned it over to get all the liquid to come out. will it be fine because it was a small amount and I took care of it right away? The coffee had milk and sugar in it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Just to be safe I would check the areas where you think coffee spilled for corrosion on the motherboard. If you find any spots where corrosion is present then use a toothbrush with isopropyl alcohol and scrub it off.
The 8-bit Guy has a video where he does this with a MacBook but the procedure is the same to clean the corrosion. Follow the respective guide for the removal of your motherboard and then clean it. If you don't feel confident doing a repair like this you could leave it alone as long as the laptop is dry, but I would strongly recommend checking for corrosion.
Video
Punteggio 0
Aggiungi la tua risposta
kimip sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 253
